sas swapped in and now drive shaft is about to hit exahust
Posted: Fri Jun 26, 2009 12:38 pm
Can i see some picks of what you guys did to your exauhst to make room for this swap? I think my front shaft is not stock as it seems fatter and it bolts right in with this eb dana 30 sas and i netted about 6"s of lift with the eb 2.5" lift coils. There is basically no room for the exaust down pipe. I think i may have to flip the headers around and do some stacks coming out the hood.
I'm going to take picks of everything for you guys tomorrow and post it up.
So far we got the toyo axle bolted in in the back w/ 4.10 gears and welded spiders
Eb d 30 is bolted in, used the eb radius arms with the stock b2 radius arm brackets, Took a bit of grinding but we made it work.
App: 84 2.8l
App: 84 2.8l
