Brake Drums
Posted: Mon Mar 23, 2009 8:16 pm
by djadjective
So my rear driver side brake shoes wore out finally, I put on a new set tonight with new springs and an adjuster kit. But, I cant seem to get the drum to slide over the shoes. I turned the adjuster all the way in and have checked my spring placement with any diagrams I have, but still cant seem to get the shoes compressed enough. It looks like the front shoe is sitting slightly higher than the back one. Anything I need to check again?
Re: Brake Drums
Posted: Thu Mar 26, 2009 5:25 am
by tydaug
Make sure the shoes are seated on the wheel cylinder in the right spot. They should both be the same height.
Re: Brake Drums
Posted: Thu Mar 26, 2009 6:07 pm
by Ranger Dave
grind the ridge off the edge of the drum
Re: Brake Drums
Posted: Thu Mar 26, 2009 8:06 pm
by djadjective
It turns out, the brake cable was old and wasn't letting the shoes retract all the way in. So, not wanting to screw around with the brake cable yet, I just removed the parking brake fork and the drum slid right on.
