low oil pressure/engine swap?
Posted: Thu Mar 19, 2009 10:08 pm
by flnative
hey just bought my 1st b2 its a 87 eddie bauer 4x4 decent shape paid 600 2.9 auto with od starts and runs fine only problem very low oil pressure do i have to pull motor to remove oil pan? also have acess to 2000 ford contour[totaled] with 2.5 would be this motor be easy or feasible swap?
Re: low oil pressure/engine swap?
Posted: Fri Mar 20, 2009 6:56 am
by clem
How low is the oil pressure? Cam bearings can cause this too. You may want to start looking for an engine. I would start running lucus oil treatment in the meantime. Good luck. :canada:
Posted: Sun Mar 29, 2009 12:56 am
by B2FunFarm
This does not mean anything big all the time. And unless you have a lot of free time and you just like the 2.5 really well for some odd reason I would not try it. Also for the 2.5 I do not think the current transmission you have in your B2 will bolt up and you have to get adapters. for a little more indepth looks at ways to solve your oil problem look at my post on the recent topic OIL PUMP.
