I have a 86 BII. Just got it tuesday. The carpet is soaked from front to back!!! Cleaned the engine today and pulled back the carpet so i could see if their was a leak. Sure as shit it was running done from behind the pedal cluster??? Anyone else had this problem? And if not any ideas???
Thanks
Jeff
Proud owner of a new to me 86 BII
Huge leak from under dash?
djadjective
Re: Huge leak from under dash?
I had this issue before, most of the water was pouring in through the passenger side and some through the driver side. Turns out, the passages behind my blower motor were clogged with leaves and sticks so the water couldnt drain except through the lower vents inside the cab. Theres a trap door you can pull or push open under the Pass. dash and access the area behind the blower motor. I had to pull the motor, and cut the mesh behind it cause there was so much crap in there.
