Need some tech advice plz
Posted: Thu Feb 19, 2009 1:52 pm
Since I am not able to get out there and wrench, (work related injury) I have to settle for surfing the net and gathering all the info I can for the up-coming engine and drive train swap in the Bronky.
This swap isn't going to be any time soon so I have tons of time to research and gather parts.
I think I have the engine swap details figured out for the most part. Until I actually start the swap.
Trannies are the hang up for me right now. I want a Ford OD auto tranny that is able to bolt onto a tcase that can be used in a doubler set-up that won't be too long to fit with the BII's shorter wheel base. This is what has been the hang up.
Eventually I want to build a doubler and this means I have limited choices for OD auto's in the Ford family. I don't want to go through the work/cost of making an OD fit and work and then have to swap it out for one that will work in a doubler set-up later on.
As far as I know I have only one choice for an OD auto that can bolt to a possible doubler set-up and that's the AOD, I hear it's a fairly long trans too, tho I'm not sure what the actual length is.
Any one know off hand what a 4wd AOD's length is? Bell to tail. I haven't looked into that yet.
From what I understand the AOD can be bolted to the np203 and doubled to the np205. I'll have to do some more searching to find out an over-all length for this combo. Unless someone on here knows?
I have a few other choices in the Ford family that are NOT OD autos.
The 4wd C6 also came in front of the np203, so a doubler later is easy.
Then there's the 4wd C4. It can be adapted to use the 1354 or 1350 tcase by using 4wd C5 auto parts. The 4wd C5 auto came in the 84-85 BII's and the 83-85 Rangers and is a fairly rare trans to locate around here. Mind you so is the 4wd C4 for that matter. The 1350/1354 have a doubler called the stubler, is there another?
The C4 also came in front of the Dana 20 tcase. I have heard about the Cold Duck kit for the Ford Dana 20, but I think it's only a low gear kit and not a doubler.
Does a Dana 20 doubler exist?
Have I missed any OD auto trannies in the Ford family that could fit the bill?
There is another route I could take, only this route isn't exactly the direction I would like to go but could potentially be fairly cheap as I have most of the parts needed.
The GM or Chevy 700R4 is a common swap for Ford guys in need of an OD auto tranny. I have a 2wd 700r4 and a th350/203 combo sitting here as well as a Ford np205. In all reality I could build the doubler to mate the 203 range box to the Ford 205 and then buy the doubler stub shaft. Actually the adapter to mate the 700 to the 5.0 is just a 3/8th plate with holes drilled in it for the 2 different bolt patterns and a matching flex plate spacer. As far as I can tell the torque converter bolt patterns match between the Ford and GM auto's around similar years. I could be wrong on that one but I feel it would be easy to adapt the 2 bolt patterns if need be. This is a last resort option IMO as I would really like to keep this Ford ALL Ford if entirely possible.
Cost and parts availability will likely be the deciding factors in the end I'm sure as I don't want to spend huge amounts of money making this all work.
Do any of you guys know of other possible directions I could go?
I really want an OD auto but could be without the OD I guess.
Has to be able to mate to a possible doubler without big dollars in adapters.
Can't be overly long as my wheel base won't allow for much more than another foot of drive train length.
I have a fm5 (?) 5 speed manual and BW 1350 tcase in the BII now (hooked behind a 4.0L V6) and they are at least a couple feet long together (trans/tcase) and my rear drive shaft is roughly 3 feet long or just under that. I also have a fw hp d44 solid axle and fw 9" rear under there too.
These are the relevant parts I have in my possession.
5.0L/M5OD/1356 combo----this combo installed in a BII makes for a 2 foot long rear drive shaft, not to mention its a manual trans and there's no doubler available and it wouldn't fit if there was.
Ford drop np205-----------extremely short and stout, came from a 79 f150 w/manual trans.
A4LD/1354 combo----------This is the V6 auto in the early Explorers and is a POS but the 1354 can handle V8 with ease.
2wd 700R4-----------------came from an 89 GM 1500.
th350/np203 combo--------came from a 79 Jimmy and has the same bolt patterns as the 700R4
If anyone has any ideas/oppinions/info/W.H.Y I would be very interested in them.
Thanks in advance
Bones
Thanks in advance
Bones
