'97 F-150 Springs and Leafs, will they fit in the B2?
LilnaYt207
Post by LilnaYt207 »
I found a guy that is selling The front springs and rear leafs from his '97 F-150, i have heard the front springs from some/most F-150's fit on the B2, the diameter is something like 3"? And then the rear leafs don't bolt up directly but what is the major modification that needs to be done? Is this worth it or do i just get the leafs from an explorer? any info will help thanks.
LilnaYt207
Re: '97 F-150 Springs and Leafs, will they fit in the B2?
Also Just found out for the front springs and rear leafs, he will pull them out and i'll take both for $70. so if they work is that decent price wise?
LilnaYt207
and now through some research, in the members rides section, i have found you can put the f-150 leafs in the rear, and i know about the front coils. any other info will still help though. thanks
LilnaYt207
How much lift will the front get with the f150 coil springs? will it be level if i put the coils up front and the leafs in the rear?
is the f150 a 4x4??
LilnaYt207
yeah it is a 4x4, but he said the front isn't coils, i may be mistaken, but they have coil springs right? now i'm not so sure i'm going to grab em if they are just the rear leafs, and if they are wider than the B2 ones.
the rears are to wide
LilnaYt207
ok cool thanks man, thats what i started to think, from reading the other forums and stuff, so for the time being we're wheeling stock height :redneck:
