Ever done an inline six swap, will it fit?
Posted: Tue Feb 10, 2009 1:34 pm
by Godzilla9992
Hey I've got an old 250 inline six that came out of my '70 maverick, ran great with loads of low end torque, has anyone ever tried to put one of these in BII, do you think it could work? also would the bellhousing be the same so i could keep the stock transmission, t-case, drive-shafts,etc.
302 swap on the mav
302 swap on the mav
Try to Pull the Bronco out With The Maverick   (didn't work)
:wtf:
Re: Ever done an inline six swap, will it fit?
Posted: Thu Feb 26, 2009 7:34 am
by Godzilla9992
Alright i figured out the 250 will not bolt up to the stock 5-speed so i'm planning on putting the old c4 tranny that came out of the mav in with the 250, does anyone know if the stock transfercase will bolt up to a c4?
Posted: Thu Feb 26, 2009 8:18 am
by Ranger Dave
Godzilla9992 wrote:Alright i figured out the 250 will not bolt up to the stock 5-speed so i'm planning on putting the old c4 tranny that came out of the mav in with the 250, does anyone know if the stock transfercase will bolt up to a c4?
NO. the only tcase that will bolt up to a C4 is a D20(the Maverick C4 isnt a 4x4 one)you need a C5 tranny(4x4 one) or the output shaft and adapter from C5 or spent BIG $$$$$ at Advance Adapters
Posted: Fri Feb 27, 2009 10:15 am
by Godzilla9992
thx for the heads up, whats going to be the best (least expensive) drivetrain to put behind the 250, i'm tryin to use any stock parts i can.
Posted: Fri Feb 27, 2009 10:47 am
by Ranger Dave
find a C5
Posted: Fri Feb 27, 2009 11:09 am
by Godzilla9992
so are you saying that a c5 will bolt up to the stock transfer case, cause that would be great
and what vehicles would come with a c5
Posted: Fri Feb 27, 2009 11:29 am
by Ranger Dave
Posted: Fri Feb 27, 2009 1:54 pm
by Ranger Dave
do you have the 250 sittin in the B2 yet??
Posted: Tue Mar 03, 2009 5:48 am
by Godzilla9992
Not yet, I'm just checkin out all the possibilities right now, i've found a 98 explorer 4.0 i'm thinking about buying for $350, but i have to give the shell back when i've robbbed everything i need. Its a complete vehicle, transmission was busted while driving by the previous owner, so its now in a junk yard. So new questions...
1. Will the ECM/wiring harness out of the 98 explorer 4.0 A.T. work in a 90 BII 5-speed setup.
2. As far as i can tell, the 4.0 OHV engine just swaps right in, Correct?
3. ANYTHING ELSE I NEED TO KNOW????? :confused:
If this is as easy a swap as i think, i'd like to get started soon, so please post on this!!!
P.S. I'm just estimating, wouldn't you say this is more economical than the 250/c5 swap?
Posted: Tue Mar 03, 2009 6:09 am
by Ranger Dave
i would rather do the 250 swap. everyone does a 4.0 swap. to be a plug in 4.0 swap, fine a 90 ranger 4.0 and get the wiring harness
Posted: Tue Mar 03, 2009 6:17 am
by Godzilla9992
In another time and place i would love to do the 250 swap, specially cause i know the engine is such a good one, but right now times are hard and i'm broke :usa: . i need something strong and dependable to drive(all i have is the maverick right now-13mpg).... and i do love fuel injection on my off road toys.
But will the 98 harness not work. I've looked all through the yards and this was the only 4.0 setup i've found that wasn't already robbed or ruined.
Posted: Tue Mar 03, 2009 7:28 am
by Ranger Dave
probably alot of splicing. look for a 90 ranger 4.0. save some head aces
plus the computer is in the engine compartment,in the fire wall on 95+ xplorers
Posted: Sun Mar 15, 2009 4:30 pm
by Godzilla9992
Alright i got a 93 explorer to do the swap, i'm just going to change all the wiring out of it into the bronco
Posted: Sun Mar 15, 2009 5:31 pm
by Ranger Dave
have fun :smilie:
