Bronco II slips out of 4WD at a bump or sudden acceleration
Posted: Sat Nov 29, 2008 10:19 pm
by iamjerry
It never feels like it locks fully into 4-H. A light push of the shifter will push it out of 4wd. It is obvious that the wheels don't grab in the snow when it slips out. The 4x4 light goes out. Speed is 10 to 20 MPH. Anyone else experienced the problem? Thanks a Mill. JERRY
Re: Bronco II slips out of 4WD at a bump or sudden acceleration
Posted: Wed Mar 11, 2009 3:40 am
by mosskie
I was out wheelin last Sunday and found mine to be doing the same thing, While rooster tailin the mud it would come out of four hi, works fine in four low. Did you ever figure out what was causing this?
Posted: Sat Mar 14, 2009 2:40 pm
by Phillippi
I had something similiar about 7 yrs ago and the fix was to access the top of the transfer case and loosen the bolt that allows the movement of the shifter IIRC. Loosen the bolt and check for the movement needed to fully engage into 4x4. Anyone please correct me if I am wrong. If I still had my stock engine/tranny I would go out and look.
Posted: Sun Mar 15, 2009 9:16 am
by Ranger Dave
you can adjust the shifter by losening BOLT "B"
