My 87 Bronco II is a wonderfully wonderful truck,
Except for the fact that it is pink,
and that my clutch/plate/flywheel/transmission decided to break.
I've got a Five Speed Manual Tranny,
And it wont move,
despite being placed into gear.
The engine just revs up.
you can also put the truck into any gear without enabling the clutch.
I'm lost.
I need help.
Pictures and diagrams would kick ass.
This bronco is lucky I don't own a plasma torch...
Re: This bronco is lucky I don't own a plasma torch...
haha i know haw you feel.
mine is doin the same, except i either cant put it into gear without the clutch, or i cant put it into gear at all... lol good luck
Shake and Bake
A bit more explanation would be helpful...I've got a Five Speed Manual Tranny,
And it wont move,
Does the BII move with the tranny in gear and the engine off? Check other gears. Same question. How or when did this happen? What were the circumstances?
From just your post, it sounds more like the clutch is having problems, not the tranny. If you couldn't put it into any or all gears, then I would suspect the tranny.
Basic question!
Does the vehicle have a driveshaft attached?
Is the transfer case engaged?
If you answered yes to both above, Go and pick up a new clutch!
That will be $38.50 please
