Page 1 of 4
Willys Pickup and the death of the bronco II
Posted: Fri Sep 26, 2008 6:29 pm
by Rockcrawler
Well i picked up a 1948 willys pickup, that will be going on the frame of the bronco II. Once i get the registration all figured out i will be pulling the body off and repairing all the rust and building up the cage using parts of the cage off the bronco. This truck will be able to drive on the road around town, still will be a far cry from street legal but i figure around town should be fine.
Re: Willys Pickup and the death of the bronco II
Posted: Sat Sep 27, 2008 7:42 am
One thing I've always insisted on is the ability to drive on the street. Are you keeping the 44's? Drop in from time to time and post up some pics of the progress.
One of the local guys here used to wheel a willy's pickup.
Posted: Sat Sep 27, 2008 2:11 pm
by Rockcrawler
Yeah it will still be on 44's and still wheeled just as hard but it will be registered. I will only drive in town never about 40. Its just to go to the ranches and cruse around in something fun. It will have a heater for one day i want to play in the snow! still havent
Right now im in the process of getting all the paper work done with it on the old frame because my bronco has full hydoilic and is a far cry from street legal if i run into any problems
Posted: Fri Oct 17, 2008 6:18 pm
by Rockcrawler
update. Still working on getting it register. I weighed it but now im waiting for a budy to come and check out the vin that some how appeared on the jeep. I got the bed off. damn thing weighed a ton!! im thinking about making my own bed now, and the dang thing had 24 bolts holding it on and the body only has 4!!! The rear axle is so old looking!!
Posted: Sat Nov 15, 2008 5:14 pm
by Rockcrawler
Finally got some real work done. Cut out the bottom corner pannel on the passenger side. I replaced with some heavy square tubing that i will use as the base for my roll cage that will be built into the body.
Posted: Wed Nov 19, 2008 6:37 pm
by Rockcrawler
finshed up the other side, Put a bunch of rust converter on the floor both inside and under. I cut out the hood air vent becuase it was too rusted.
Posted: Sat Nov 29, 2008 8:01 pm
by Rockcrawler
Got some more body work done and started tearing down the bronco II
Posted: Sat Nov 29, 2008 8:02 pm
by Rockcrawler
more
Posted: Sun Nov 30, 2008 7:12 am
Thanks for the update. Looks like you're almost done
Posted: Mon Dec 01, 2008 4:44 pm
by Rockcrawler
got the body on and brouht the front clip around to see how it will look. This is with the front air bags all the way down. the clip can go down some more so it should look pretty good!
Posted: Sat Dec 06, 2008 4:27 pm
by Rockcrawler
Got the 351 in and the c6. Ran into some problems. The passenger side exaust goes right into the frame and when i welded the cracks it made the exuast shorter. So i will have to grind a little on the bolts and cut the manifold and reweld it so it will work with the truck. I put the front clip on to see how its going to look. It will have to sit up about an inch or two higher to clear the motor. but it will look good when done! its going to be a big beast!
Posted: Thu Dec 11, 2008 6:14 pm
by Rockcrawler
HOLY SHIT THE BRONCO IS ON FIRE
Well boys and girls i learned a great lesson today! I was just tourching off my old rocker pannels on the bronco II frame, real quick so i dont have the fire extengusher close by or anything smart like that. (I had been tourching on the other side of my shop earlier so the extenguisher was over there) When i got done with the one side i noticed a little flame inside the frame rail! I thought nothing much of it i have had this happen before were there was some old grease built up in there, so i blew on it. Then i realized it was a fuel line that was buring!!! FUCK!!! So i run over to the garden hose, and by the time i turn around Its bursted into a huge fire thats up to the roof of the overhang. I start spraying it down with little effect. Luckly some kids and there mom where out playing and they called 911 for me. I called my roommate to come out and help (he is also on the fire dept and my brother is). a guy driving by helped too with a hose from next door. I had three hoses on it and it finaly started to calm down. There was fire on the ground and fire running up towards the gas tank and towards the engine!! When the fire dept got there (and they got there quickly) the fire had been brought down to a pretty small size. Thanks god for small favors that nothing important burnt up and everyone was ok. I got a small burn on my hand, and a brusied ego. (my dad cought his house on fire a couple years ago and we all gave him a hard time about it guess its my turn now). I was going to redue the wires going back there anyways and now new fuel lines. So the moral of the story is always and i mean always have a fire extenguisher handy! I also took the old jeep frame to scap today here is a cool pic of them unloading it.
Posted: Wed Dec 17, 2008 7:32 pm
by Rockcrawler
well got a new hood and put the body on!
Posted: Thu Dec 18, 2008 4:32 pm
by Rockcrawler
dropped the body an inch and a half and mounted it all up. This is at ride hight
Posted: Sun Dec 28, 2008 8:57 am
by Rockcrawler
got some work done finally. I had welded up some cracks on the exhuast manifold but like a dumb ass i did it off the motor so it worped it. I had to cut it in half and bolt it up then weld it on the motor. i also had to cut and reangle the exhuast flang on the manifold. I took the front clip off to clean it up and make working on other things easier. I mounted the drivers seat. Put in the brakes other then a few finishing touches on the brakes.
