so theres a 84 bronco2 on craigslist for sale and the guy is asking for 800. i know i can talk him down so thats not a problem. what is a problem is teh carb. apparently it needs a new carb or at least a rebuild. as far as i know thats all it needs. im gunna go check it out tomorrow hopefully. there was a bronco on my street for sale that matches the discription this guy is giving. so if it is that same one it kinda wierds me out cause to me that means theres something wrong with it that he doesnt wanna take care of.
anyway i was just wondering if anyone has an idea on how i should go about this. should i get a new carb or have it rebuilt? i only have around 2-3 after i buy the truck itself. and if a rebuild is what your suggesting does anyone know of a cheap place in orange county?
need help with 84 b2 carb
Re: need help with 84 b2 carb
I just responded on the member rides section.
One thing I did was look in the phonebook and started calling places. I went with a place called automotive rebuilders: rebuilders of all sorts of parts.
I then went to the better business website and plugged in that companies phone number for results.
Goodluck
Tell the guy you will already have to spend a couple hundred on the carb and then you will have to follow up with plugs and etc... That should help in price negotations.
Goodluck
vabronconut
if you are mechanically inclined at all i would buy a rebuild kit and do it myself. tip for ya- only take apart what you have too !!! leave the linkage and adjustment knobs alone. most carbs go bad from a bad accelerator pump or diaphram, or the fuel bowl is varnished, or last is the float is bad. so only take apart what you have to, to get to this-- which is usually the front bulge housingxeducatex wrote:so theres a 84 bronco2 on craigslist for sale and the guy is asking for 800. i know i can talk him down so thats not a problem. what is a problem is teh carb. apparently it needs a new carb or at least a rebuild. as far as i know thats all it needs. im gunna go check it out tomorrow hopefully. there was a bronco on my street for sale that matches the discription this guy is giving. so if it is that same one it kinda wierds me out cause to me that means theres something wrong with it that he doesnt wanna take care of.
