2.9 or 4.0
2.9 or 4.0
What would you do? Put money in what already had, or buy a explorer?
Re: 2.9 or 4.0
thats kind of open ended...
what exactly are you talking about just motor? or getting a whole new truck?
Re: 2.9 or 4.0
Sorry about that. I have a good deal on a donor explorer.
Re: 2.9 or 4.0
well, the good thing is if you get the whole truck is you are getting more then just everything under the hood if it is 4x4. you will also score a D35.
I would definatly recomend having both trucks setting next to each other when you do the swap. how good of shape is the explorer in?
Re: 2.9 or 4.0
Been hit in the rear, but other then that ok
Re: 2.9 or 4.0
im with you setting the two side by side , it would be a great swap engine and all. i have a 2000 explorer sport that i use as a daily driver and i love the 4.0 it has. its a quick sucker !DBrown wrote:well, the good thing is if you get the whole truck is you are getting more then just everything under the hood if it is 4x4. you will also score a D35.
also you will get the 8.8 rear axle to replace your weaker 7.5
all kinds of up grades out of one truck!
