What gearing do you run?
stevenf
Post by stevenf »
Im building my GM 12 bolt which has 3.73's. Im wanting to run 35's-37's and was wondeirng what gears yall would run with 35's-37's. Would the 3.73's work, I just wouldnt have my top speeds anymore?
TJDukit82
Re: What gearing do you run?
Post by TJDukit82 »
Like you said you wont have any top end and your get up and go is not going to be that great with that big of a tire. If you want to wheel it that 6 cylinder might have some trouble getting it around the trails with those big meats.
'89 Bronco II
'03 GMC Sierra Z71
vabronconut
Post by vabronconut »
i have run 35's with 3.55 gears. it did ok on the trail, did rear good on the highway but it was in a f-150. for 35's 4.10s are great because they do good on the trail and on the highway. are you running a automatic or stick?
vabronconut
just thought i would add, i have 4.88's in my axles, with 38 in tires. and it will be stricktly a trail truck, i don't think it will be worth a damn on the highway or the engine will be screaming.
NastyBronco2
Post by NastyBronco2 »
If I was You i would get 5 13's best Thing I ever did with my 89 bronco I run 38's
runnin 37's wit 737 will get You by i Would really Recamend 5 13's
