no wiring for stereo what now?
stupidcow79
just wondering how you could wire up a stereo if there were no factory wires availible just need to no what i should connect to power and stuff
vabronconut
Re: no wiring for stereo what now?
you can gound it to the fire wall, and take power off of the fuze block, any wirethat is hot in the run position will work and any parts store sells a wire connector that will tap into another wire without splicing. you can take the wire off of the cigarette lighter and use it as memory back up power, not as primary power or you will have to turn off the radio every time you get out of the truck
stupidcow79
thank you helped out alot finally got a radio
