205 divorce t-case
QuickNCrazy
205 divorce t-case
has anyone shoved a divorced t case ina b2 i got 1 in my 78 ford and i would liek to put the 1ton running gear in b2
vabronconut
Re: 205 divorce t-case
the length of the trans/transfer case being divorced is too long for the bii, your rear drive shaft angle would be too much. you probably could do some research and find a way to turn your divorced case into a standard married type.
im doing on in a xtra cab ranger. this is as far as ive got
http://rangerdave.freeforums.org/the-tractor-t21.html
