I have a 1984 BII that had a 4 speed manual tranny. I am installing a F145 4speed w/OD from a 1987 BII into it. Can I use my old tranny support and move it back on the frame? Or, must I install the newer support that used the external perches? Any info would be very appreciated. Thanks in advance.
I make my x-member bolt to the radius arm brackets and kicked it back to the trany mount bushing. It took some cutting and fabbing but if you have all the tools its not that hard. I have the stock A4LD on my 87 though.
