My son and I are fixing up his free 1987 Bronco II. The drivers side rear shock mount has rusted away and the Ford dealer says it's obsolet with no replacement. Do i search junk yards? aftermarket companies? fabricating it is beyond our capabilities. any help greatly appreciated.
Chris
rear shock mounts
Re: rear shock mounts
that is where I would start. might try bronco graveyard.Do i search junk yards?
if it was me I would go to the local help yourself type junkyard and grind the rivets off a decent one and then bolt it in... you can also use a chisel and hammer to knock the heads off the rivets... my fav tool is a air chisel
4x4'ers Eat More Bush!
I assume your talking the upper mount, so ya junk yard. If you can, grind a X in the rivet head using a cutting wheel on a grinder then use an air chisel or regular cold chisel to knock,er off. good luck
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
Thanks for all the responses I think i found one at the graveyard
