no spark on 88 BII
Posted: Fri Apr 25, 2008 5:16 pm
by steven88B2
im not getting any spark from the coil on my bronco. ive tried changing the coil but still nothing. i have power to the coil but i dont know the next step... any suggestions???
Re: no spark on 88 BII
Posted: Fri Apr 25, 2008 8:38 pm
Need some basic info like year and engine model carbed or FI.
Can't even suggest until we know the basics.
Posted: Sun Apr 27, 2008 5:26 pm
by steven88B2
1988 BII with stock 2.9 liter V6 fuel injected
Posted: Mon Apr 28, 2008 4:13 am
pull the mod. off the side of the distributor and have it checked at autozone. they do it for free. just have them check it more then once because it sometimes will check good the first time then fail when it gets warm.
Posted: Mon Apr 28, 2008 9:08 am
As D Brown said, Have the TFI module checked. It is that funny looking block attached to the side of the distributor.
Posted: Mon May 05, 2008 1:23 am
by steven88B2
thanks, will try it
Posted: Thu May 08, 2008 6:03 pm
by steven88B2
i havent tried the ignition module yet havent really had time. but i have another question. the thing is that my bronco shut off while i was driving so could that be the ignition module or more like the pick-up coil?
Posted: Thu May 08, 2008 9:22 pm
My first guess would be the TFI, however the unit in the distributor has been known to fail. The typical symptoms would be quitting when warm and won't start back up till it cools. Sometimes it never starts up.
Question? Have you checked to make sure you have fuel pressure?
One more item. It the vehicle quit after hitting a big bump, or tipped or bounced and won't restart check the rollover switch on the firewall passenger side inside. there is a reset button that you can push to reset if that is your problem.
Posted: Sat May 10, 2008 1:05 pm
by Godzilla9992
I just ran into the same problem on my recently purchased 90 BII. I was in the middle of making a turn and it just died. It turned out to be the pick-up inside the distributer, which requires removing the distributer and completely disassembling it. If this is your problem, take great care when removing the shaft from the housing, a penetrating lubricant and patience will most likely be required. I ruined one distributer shaft trying to hurry the process, luckly I had a spare on hand.
Good Luck.
Posted: Sat May 10, 2008 3:10 pm
by steven88B2
the inertia switch was the first thing i tried even though i wasnt wheelin at the time. im gonna switch the pick up later on today.
Posted: Sat May 24, 2008 1:15 am
by steven88B2
alright sorry it took me a while to get back but i ended up just changing out the whole distributer but its still not firing. im stuck i dont know what else it could be. any suggestions???
Posted: Wed May 28, 2008 11:57 pm
by steven88B2
alright thanks for all the help i appreciate it. turned out to be ignition module and ignition coil even though they were both tested by autozone before and were good last time. oh well got it running so thanks again
