Well... I thought I was almost done.
Posted: Fri Apr 25, 2008 5:29 am
by onewontwo
I have my rear done, all the brake lines done, etc.
What's missing?
My drag link and the rest of my steering.
I do have everything off the stock EB.
However, I've been doing research and I'm finding out it may not work?
Can't I just get a drag link made up and be done with it or do I have to go with the high steer set up?
Re: Well... I thought I was almost done.
Posted: Fri Apr 25, 2008 7:36 am
by texastud1983
Try is and see if it will work or not. Your biggest problem is going to be the length. I used the stock drag link of of my BII as a lemp. fix. Now I made my own hi-steer and I used crom-oly rod ends.
Posted: Fri Apr 25, 2008 9:38 am
by onewontwo
Any part #'s for the tie rod ends?
Posted: Fri Apr 25, 2008 2:24 pm
by onewontwo
Can any one confirm these part #'s for a hi steer set-up?
Hopefully I did enough research and ordered the right stuff!
TRE - ES2233L and ES2234R
DLE - ES2026R and ES2027L
I understand I will have to be doing some fabrication once I pick these up tomorrow.
The one thing I couldn't find in the short amount of time I had was the size of DOM tubing that I need. Length / I.D. / O.D.
Thanks in advance!
