Mounting Rad in back of Bronco
I got a chop top bronco 2 and want to mount my rad in the back. I have a 302 c6 1356 with fullsize dana 44 and 9 nich but dont know if the water pump will work or how to plum the system can so one help. thanks
Re: Mounting Rad in back of Bronco
I'm pretty sure that you can use your stock waterpump. I'm not sure about the plumbing though. If you use PVC it would have to rated for the high temps.
You should use aluminum piping it will help disipate heat but might get to cool
http://www.wefabricateit.com check this site out and help us build it up
I used water pipe thats made from steal so i can weld it. I used the stock water pump but make sure not to run the car without water because it will tear up the seals on the water pump. here is a link to mine http://forum.sanjuanrockcrawlers.com/sh ... 375&page=2
I sort of thought you had a rear mounted radiator, but I was pretty sure you had a back seat too.
I used to have a front one till i did the 5.8L swap because i wanted more space up front.
