budget lift for my bII
Posted: Mon Mar 31, 2008 9:21 pm
by floridamudslinger
Any info on a cheap lift for my bronco i want to clear 33s. will 4 in blocks in back and coil spring spacers in front work?? If so what do i use to keep the front tires aligned? Also will ford explorer suspension work on the bII?
any info will be greatly appreciated thxs!
lift
Posted: Tue Apr 01, 2008 2:49 pm
by vabronconut
3" body lift and some cut out flares are the cheapest, i have never used spring spacers, so i don't know about that.
Posted: Tue Apr 01, 2008 4:40 pm
by onewyr
I ran 32x11.50's with explorer springs, spacer in the front and a 2" trim job
cheap lift
Posted: Wed Apr 02, 2008 2:58 pm
by clem
Coil springs out of a ranger stx,with auto trans and air cond have a higher spring rate,thus raising the front. Getting yor rear springs re-arched with aleaf added will do the rear.Fender trimming still req'd.This worked for me until I was ready to go big.
Posted: Wed Apr 02, 2008 6:09 pm
I'd highly recommend staying away from blocks and spacers. Cut those fenders!
