so my 86 b2 is idleing odd
some times it will idle aroung 3000rpm and stay their consistantly
and other times it will sit at 1200 and fluxuate between their and 1800
what is it
idles funny
yodaman1151
my 87 when i got it would sit there and rev back and forth up to 2000 or so until it warmed up. when i swapped the motor i had noticed that when the guy before me welded the nerf bars on, he melted a vaccuum line going to the gas tank. i put a rubber hose with 2 hose clamps and it idles just fine from startup.
regulate34
pigmy pony
Recently mine was idleing at 1500-2000 RPM so I took the AIC and the throttle body off and cleaned them. They were both filthy and the AIC had a small twig in it. Two weeks before I went through a mud bog and so much mud got on my air filter that the next time I started it, the filter just riped in half because it wouldn't flow any air. Just something to think about or check.
Momentum and wheel spin
yodaman1151
