What electrical accessories are a must on your rigs
onewyr
Post by onewyr »
The reason I am asking is because I have some cable left over from a job I did awhile ago that has 15 14 guage wires in it so I ran a piece from the driver side rear tail light up to the front and around to where the fuse box sits and then another piece from the dash board up to where the fuse box sits. Here are my thoughts, so far what I have planned it the piece that goes to the dash is gonna all be switches and leds. the first wire will be for the common to all the switches.
1 common
2 on-board air
3 rear flood light
4 front flood lights
5 E Fan
6 spare
7winch common
8 winch in
9 winch out
10 spare
11 spare
12 spare
13spare
14 spare
15 spare
the piece that goes to the back well there is just gonna be alot of spares cause all I can think that will go back there is the back lights and maybe an elocker in the future.
of coarse there will be fuses and relays involved under the hood but that is the simple part I am just curious what accessories you guys have on you rigs
Mine is simple. Power run to amp (not big, only for good sound), power to CB. Other then that im plain inside. Who knows when I get this done (if ever) what I will add.
yodaman1151
Post by yodaman1151 »
i just have power to amp, cb and in future i'm installing kc lights up front, and on board air
Bob Myers
Post by Bob Myers »
Other than factory items, power to both ham radios, and to CB. 00 ga wire running to rear so I can plug in a set of jumper cables if need be. Perfect for pulling over on side of road and jump starting someone without turning around. Was originally set up for my winch when it was on 2" receiver.
92 XJ-wifes toy
