on-board air
yodaman1151
on-board air
i'm converting my a/c pump to air compressor, nothing new, any tips? i have an auto air tool oiler to lube the pump, getting a pressure switch, and a toggle switch, pressure blow off valve and trying to decide on a tank. also an idea i had was to use a cable that i could put under the hood to hold my throttle up for faster pressure build up.. comments please
http://bryan.hartmania.com/2007/06/24/o ... bronco-ii/
this is how I did my on-board air in my 89 b2
yodaman1151
yodaman1151
yes I had to thread it because where the regulator and oiler meet the holes are not threaded they make the seal by using a "O" ring. there is a band in the middle with a couple of bolts if you pull the bolts and then the band or mount they will seperate and then you gotta use a 3/8 NPT tap or maybe a 1/4" NPT tap it has been awhile since I did it. I am not to impressed with this particular oiler it doesn't work all that well it says adjustable but that is a joke , but i guess it works ok cause my pump has not burned up yet. When I wired mine up I just use the a/c button but the problem with doing that is when you select defrost it turns the pump on I am not sure why but I do know others have had the same problem. I would set a fuse and a switch so it is not affected by turning the defrost off. I plan on re-wireing my system, WHen I do this I plan on putting an led in the dash so that it lights up when the pump is on.
yodaman1151
