Page 1 of 2
Nobody's 1970 Bronco
Posted: Sun Jan 06, 2008 9:41 pm
As some of you know, I retired my Bronco II. For the last year or so, I have been working on my 1970 Bronco.
It's was mostly stock when I got it. 302, 3sp, Dana 20, Dana 30 Front, Ford 9" rear, ,manual steering, manual brakes. You know, all the bells and whistles.
Here is a list of upgrades I have been working on. It's been a long slow process. But I'm getting there one step at a time.
- 5.0L HO from a 1992 Thunderbird
- NP435 Transmission
- Dana 44 Front axle
- Power Steering
- Hydroboost Brakes
- Chevy Tie rod conversion
- Tru-kool Aluminum radiator
- Gorilla War Flares
- 20 Gal Fuel tank
- 3.5" suspension lift
- 2" Body lift
Posted: Mon Jan 07, 2008 4:32 am
looks like you are moving along! how well did the NP435 shifter fit?
Posted: Mon Jan 07, 2008 4:41 pm
Hey that Looks GOOD man.. I like professional workmanship!
BTW what size and type of tire is that front tire on your bronco?
Posted: Mon Jan 07, 2008 6:38 pm
DBrown wrote:looks like you are moving along! how well did the NP435 shifter fit?
With the 2" body lift, it fit perfect. My hole was a little off though since the tranny isn't centered on the tunnel. I don't think I can remove the tranny without removing the engine at the same time. I'd have to cut the hole bigger to be able to slide the tranny back. It was a real SOB going in with just one person. Mostly because of the small hole.
I'm not quite done reshaping the shifter. It still hits the twin sticks a bit in 2nd gear. Might just chop down or ben the twin sticks instead.
Posted: Mon Jan 07, 2008 6:41 pm
tekatlarge wrote:Hey that Looks GOOD man.. I like professional workmanship!
I wouldn't go so far as professional. For me it's a balance between making it nice and actually getting it done. I don't know how some people do such nice work. I would have liked to clean up and paint more, but that will have wait a few years. Most of the stuff I took apart I did clean and paint before going back on though.
Tires are my 36x12.50R15 Radial Swampers from my Bronco II.
Posted: Tue Jan 08, 2008 5:25 am
I have always heard that you had to hack a big hole in the pan to get it to fit but that actualy looks better then I thought it would.
so did the np435 bolt to the original cross member?
Posted: Tue Jan 08, 2008 6:15 am
I already had the AA NP435 adapter on my Bronco II. So yes it uses the factory crossmember. I also purchased the heavy duty motor mounts on a mass buy last summer.
Posted: Wed Jan 09, 2008 5:46 pm
by ranger5.0
Looks like you might need new tires... Those don't hold air very well.
Looking good.
Posted: Sat Jan 12, 2008 7:34 am
are you going to use the rear from your BII or stick with the 9" from the EB?
Posted: Sun Jan 13, 2008 8:00 pm
I will be putting in the Dana 60 from the Bronco II.
I reassembled the wiring harness in the driveway today. I took 99% of the wiring from the car. about the only thing cut was the stuff going into the doors. I still might pull the keyless entry touch pad. Seems like it might be usefull for something someday.
Posted: Sun Jan 13, 2008 8:03 pm
The Donor:
1992 Thunderbird
5.0L HO
99,000 miles
Posted: Sun Feb 24, 2008 9:17 pm
Posted: Mon Feb 25, 2008 4:55 pm
so you plan to keep the underside of that thing that clean from now on?
the welds look good to me, did you buy a tig?
it's looking good, is it close to getting back on the road?
Posted: Mon Feb 25, 2008 6:26 pm
I hope to keep it pretty clean of mud. Grease and oil seem to do wonders for rust prevention.
I think it's close to being back on the road, but I've been saying that for over a year now.
Now I get a few hours a weekend vs all weekend 20+ hr missions. I still look at a project and think I can knock it out in a weekend....then the wife and kids bring me back to reality.
Major projects left:
- Finish Exhaust
- Install Fuel tank
- Plumb fuel lines
- Install radiator
- Wiring
- Finish plumbing the hydroboost and power steering
At that point it should be driveable. Then I need to:
- Install Rear Dana 60
- Install York On Board Air
- Bumpers
- Fender Flares
- Roll Cage
Then I'll be on to paint/body and other pettty stuff. Probably on the 5 year plan.
I'll reply to your welder thread in tools.
Posted: Sat Mar 08, 2008 7:49 am
by Bob Myers
Looks great, simple straight forward and tough. My opinion, and only a suggestion mind you but,, I would cut the exhaust pipe in two right past the left/right miter joint and put either a flat flange or a header collector 3 bolt flange in there to facilitate the removal of some of the exhaust for tranny/clutch repair.
