Need New Balls (Rear Door Damper Hinge Balls)
Posted: Sun Dec 02, 2007 6:10 am
I’m getting tired of using a piece of wood to hold up the rear door on my ’87 B2. I’ve seen the replacement dampers on eBay for ~$25, but my problem is the heim (hiem?) joint balls on the cab that the damper attaches to have rusted and broken off also. The L-shaped brackets appear to be tack welded on, with a small space on the backside to possibly install new balls, once I grind down and drill out the rusted remains of the old balls.
Has anyone dealt with this? How? Are new “balls” available? Where?
Thanks.
CraigK
Thanks.
CraigK
