Can I disconnect my sway bars?
Posted: Sat Nov 17, 2007 8:45 pm
by Forest Falls Crawler
I have an 86 Bronco II with a 6" Skyjacker lift on it and a 3" body lift with 36" super swampers. In the future I plan to convert the front axle to a straight axle set up. For now I am broke and will be using the stock front suspension set up. I want to know if I can disconnect the front sway bars for more travel. I have not been able to find a quick disconnect set up for the Bronco II, so I am guessing the answer is no, but I would really like to know for sure.
Posted: Sun Nov 18, 2007 9:47 am
by ranger5.0
You can disconnect them. It does affect handling on the road. I built my own extensions. I found that with the IFS it seemed to work better with the fronts still connected. loose the rear one though.
Posted: Tue Nov 20, 2007 3:52 am
by Rockcrawler
make sure to make a mount to hold the coils in up top beacuse i took my sway bars off and had a coil pop out once!!! it sucked because it the ripped my brake line.
Posted: Thu Nov 22, 2007 1:07 pm
by Bob Myers
I have EVERYTHING you need to do a sas, dana 44 front w/disc brakes, new calipers and rotors/bearing, 9" rear with lincoln lock,it was pulled from a running driving BroncoII to facilitate the install of rockwells. All is there, including the trac bar and frame mount for it. All located in Ky.
Posted: Sun Nov 25, 2007 2:19 pm
by onewyr
how much for the sas stuff
Sway Bars
Posted: Sun Dec 02, 2007 6:49 pm
by AllOut84
I have a 6 inch lift with 33's and no front or rear sway bars and I drive mine daily little bit of sway when turning hard or jerking the steering wheel back and forth but other than that I like it never had a coil spring come out or anything yet.
Posted: Mon Dec 03, 2007 5:40 pm
by ranger5.0
I have lost springs with too long a shock. Definitly use j-hooks to hold the spring in. It is a pain to pop the spring back in on the trail.
Posted: Tue Dec 04, 2007 6:12 pm
by Bronco Ollie
i say take them off i had 4" lift and 3" body lift on my old truck and it was fine without them
