88 eddie bauer to 84 b2
Will a rearend from a 88 eddiebauer b2 fit in a 84 b2 the 84 is a 2.8 the 88 is a 2.9 efi also how hard a engine swap would that be the 2.9 into the 84 b2 also ... the trannies interchangeable?
I`d dare say since you`re going from a carbed engine to FI, your entire fuel system will needd to be changed to the FI setup,which would include the lines and the tank. I think this would be more work than it`s worth. Plus the engine compartment wiring will be different due to the FI and it`s need for all the engine sensors.
If you have 4wd then and the front and rear gears dont match it will bind and something will break. If its only 2wd then you will be fine.
On the rear bolts of the 7.5 there should be a metal tag with the ratio on it. If not count the pinion revolutions to the 1 tire. So 3 1/2 piion turns to one tire is 3.50. 3 3/4 to 1 is 3.73, etc
Ok thanks that should be pretty easy I have both here makin one bitchin ride out of 2
ok next question the eb has power windows and locks, doors are cherry on it i would like to just have the windows work not real interested in the locks working. theres a harness of 8 wires in the plug. black , red , blue/black, yellow/black pink/orange,pink/yellow , pink/black, red maybe just a few jumpers and a power supply but where should I start?
No, changing transfer case would not cure mismatched rear/front gears.hushmoons wrote:also if the ratios on the rearends differ would that just require a transfer case swao because mine leaks a bit in the 84 anywya i plan on swapping most evrything i can the eb has bad rust problem in back end or i just drive her my 84 is from Ga. good shape she is
If they are different just swap the front pig too, you probably need new ujoints any way so change them while you're there.
92 XJ-wifes toy
92 XJ-wifes toy
