My '87 B2, AT 4WD is overdue for rear shoes. (Manufacture date 6/87.) Problem is, I cannot get the drums off. It almost looks like the drum is part of the axle hub??? with no "crack" visible around the hub???. I've been using release agent and beating on the drum with the backside of an axe, and still no-go. My POS manual shows separate drums like normal, but a bit of a different hub design.
Is there any models that had the drums integral to a hub piece? Or do I just have to keep beating on this sucker to get it off. (Any more beating and I don't think I'll be able to re-use the drum.)
Any help appreciated! Thanx.
CraigK
HELP! Rear Brake Drum Removal
Happy_Jack
Next time you have this problem make it easy on yourself. Some auto parts stores rent tools. What makes the job easier is a large 2 or 3 jaw puller. Make sure you have white greese on the threads of the puller. As you tighten it use the hammer to hit the end of the threaded shaft where you use the socket or wrench to tighten. If the Auto parts store won't lend you one they can be rented at most rental stores.
You can also prep the job with a wire brush and PB Blaster. Now that you know where to prep.
greenmachine89
