anyone know how to take the fan off?
Posted: Sat Jul 21, 2007 10:51 am
by lukesb2
im swappin 2.9's at the moment ( i like to keep my b2 a little original) and i cant get that fricken fan off... its really p**ing me off
.. anyone know?
Posted: Sat Jul 21, 2007 11:00 am
by BDEUCE
looking from above, you have a space between the fan and motor (duh), look down into the space and you should see the shaft of the fan. it mnight be odl and oily and dirty, but is a hexagonal shaft. put a wrench on it, and left hand thread. don't have a wrench that big? vise-grips, or a strapwrench worked for me. helps if you have the belts hooked up i guess.
good luck
Posted: Sat Jul 21, 2007 9:58 pm
by Phillippi
If this is the fan on the fan clutch then you will have to use a ford tool for this. It consists of a wide u shaped wrench that goes over the 4 bolts of the fan clutch. The use a large wrench to go over the hexagon shaft and it is turned opposite of normal. I hope that makes sense.
Posted: Sun Jul 22, 2007 11:13 am
by lukesb2
thanks.. it came off with just a regular wrench
