First of all you want a 4.0 DOHC type motor so would be before a motor made before 97 .................yes i used the same mounts, just unbolt one motor and bolt the other in same place with the same mounts...... tranny, T case, drive shaft from your truck just reuse...... just drop and bolt ...... the only difference is the wiring, the 2.9 runs with a distributor,( 4.0 DOHC )uses EDIS module electric distributorless ignition system)...... you would have to have the wiring harness from the 4.0 motor including the EDIS module which is located on the radiator support behind the battery on an explorer and says right on it EDIS... and a chiltons manual then cut and splice according to colors for each motor.... its probably the easiest and cheapest of the motor swaps for the BII .... DONOR VEHICLES>>>explorer 91-94 is good for the swap, 94-97 maybe but in 94 they went 2 using 2 oxygen sensors so would be more difficult to wire, but in 97 they went to SOHC, i have heard it wont work, the aerostar van runs 4.0 DOHC v6 i hear it works....and there might be a couple of others vehiclesbut im unsure what year on the aerostars, and rangers, but you might ask ranger5.0 on the rangeer years, and i think Dbrown did one from the aerostar, i did mine from a 1991 explorer and it runs beautifully, more power, and not much heavier than the 2.9 mnotor was its like an extra 60 - 80 HP jump... to go with the 4.0 and it wont kill the stock front end or rear end..... you might want to try to grab the 4.0 radiator as its a duel element and the 2.9 is a single but the 2.9 and 4.0 will interchange on the radiator, other than the 4.0 has 2x the cooling capacity.
i used my 2.9 starter, tranny, flywheel, clutch, t case, and just pulled motor only, and reinstalled with the rest still in the truck.... well removed starter and reinstalled it after the motor was in...... if you have trouble with the edis wiring it in let me know .......
paulbelden1@sbcglobal.net ....
ill try to help with it i have an 1989 BII XLT..... so i have a pretty good idea the wire colors from the 2.9 distributor for that year when your ready to do it and can help with the locating of them and how they match the to the EDIS module.
