will a computer from a two wheel drive 1989 ranger work in a 1986 b2 with an EGR valve. If so can I eliminate the EGR. Or is the a way to eliminate the EGR valve to eliminate the faults I'm getting??
--L
ecm question
ecm question
i dont see why the egr would matter. if you disconnect it you'll get codes but it should'nt have any negative effect on the engine. i know there are a couple of threads over at www.fullsizebronco.com that probably could give you a more definite answer for you.
I would say no, unless you grabed the harness and all. but then you would run into problems with connecting it to the plugs at the fire wall. best thing to do is to get one from an 86. where are you located? I thought I had one around here some where, I can look if you need it it is from an 86 with a 2.9L.
the EGR is not that bad to replace. I would just fix it so it will run right and get the best gas milage. I think they run around $40 at autozone.
