close call......FIRE
:wtf: i blowed passenger side head gasket this morning on way in from work just pulling in front of my brothers house, blowed out through the oil return ports......oil all over exhaust manifold and started flaming where it blowed out through cylinder head, i was planning on doing engine swap to 4.0 next week so guess i need to start sooner, but lucky for me i yanked off my shirt and smothered the flames out........ but it really spooked me for a minute, i thought my bronco was a goner when i seen the flames after i opened the hood.......i thought the smoke when i seen it under the hood was it overheating....... boy was i wrong..... but im glad checked to see though...
guys i got an extinguisher but being a maintenance electrician i know that dry chemical extinguishers severely damage electrical components, and i want mine in top shape for the engine swap and since i caught it quick enough i did the most reasonable thing.........by bye work shirt........hello to the reason for an engine swap......oh and so you know i found an 4.0 complete with harness.........out of an explorer made 11/90 so think im in good shape.........hopefully it bolts in like everyone says they do.....I guess i will find out this week..............so bye bye stock Bronco II time for the upgrades to start......oh and i found it has all the springs under it too......hmmmmmm......i hear thats 1.5 inches of lift anyone know that for sure????
cause i wanted 2 inch of suspension lift with 3 inch body....dont want 4 inch suspension lift but was thinking i might have to go that way....
now im thinking 3 inch body lift with explorer springs.........thinki can get 31's that way easy but wondering bout 33.....probably have to trim huh...
well guys i plan to change the front and rear axles too out of the explorer and just install a 4 inch suspension lift, to hell with the body lift
, if im going to do the upgrade from the explorer to the newer suspension i might as well lift it up where it ought to be for better clearance
.....so im going with a 4 inch skyjacker when i do it
........ and the 4.0 is in now, is running good, yet seems to be running quite rich though, im going to put it in the shop and have the wiring checked to see if it was something i did, might be becasue i used the 2.9 oxygen sensor, either way i want it to run the best it will. so wont hurt to have it checked by someone smarter than me on this issue, and a buddy of mine runs a shop so im going to have him recheck it all, no need to cause myself more problems if you know what i mean, 1 fire was enough for me ......
, and then it will be time to think about that buying my lift kit......
