I don't wanna break it....how does it come off?
Posted: Mon Apr 30, 2007 9:04 pm
				I'm pulling a motor and there's a few things on the '88 BII I can't get apart, or off :
-I removed the five bolts holding the fan blade clutch/pulley assy. to the water pump, but I can't pull it off the pump. Whats up with that? (I notice the shaft between the pulley and the fan clutch is hex shaped...do I put the pump impellar in a vise and un-screw the clutch from the impellar shaft)?
- how do you remove the wiring connectors from the fuel injectors? Looks like there's a metal spring clip ? ? ...mayby you pry it back with a tiny flatblade screwdriver? ( Really don't want to break 'em).
- Same deal on the fuel rail. how do you free the metal spring clips where it attaches to the injectors?
thanks, dave
thanks, dave
