couple of questions
Posted: Mon Apr 16, 2007 7:57 pm
by PHROX
ok, I have a couple of questions. I got a 5.0 out of a 93 Thunderbird, its in and running, (had some trouble with the drive shaft but its all sorted out) my questions are....
1. I am keeping the guage cluster from the t-bird, but the fuel guage doesnt seem to be compatible with the BII sending unit. Is there an easy fix? or should it be compaible?
2. does the oil filter relocator raise the oil pressure or do I have another problem?
Thats it for now. thanks
Posted: Mon Apr 16, 2007 10:55 pm
by Phillippi
Hello and welcome back Phrox. I wish I had a real answer for you on your questions, but I dont. Good luck.
Posted: Tue Apr 17, 2007 6:00 pm
by 84_4x4
could always buy a sending unit for a thunderbird or take the one out of the donor vehicle and as far as oil filter relocator i would have to say no on oil pressure but would cause it to require more oil but ive always heard more oil pressure is good as long as it dont blow out seals
Posted: Tue Apr 17, 2007 7:39 pm
Don't know about the fuel guage. How come you want the to use the t-bird cluster?
As for the oil, no the adapter won't raise the pressure. The sending unit on your t-bird motor is probably just a switch for the dummy light. It should be a canister looking thing.
Got any pics of your conversion?
Posted: Wed Apr 18, 2007 7:55 pm
by EBSTEVE
You have another problem with the oil pressure, how much do you have? The sending unit for the BII and the T-bird must be different, so you will have to get either a gauge or a sending unit that matched the ohms full and empty.
I have a 93 t-bird motor in my EB and love it.
Posted: Thu Apr 19, 2007 4:22 pm
by cddavis9343
check your oil sending unit. but i've also heard no such thing as to much oil pressure.
Posted: Thu Apr 19, 2007 4:32 pm
by PHROX
The oil pressure is about 3/4 up the guage. No pics, they are all on my phone, I will have to get them off sometime for you guys and do a write up or something. Its pretty sweet. oh, and the reason for keeping the t-bird cluster is because its a digital speedometer and also didnt want to mess with guage incompatability. Such as the fuel guage for instance. Did I mention its pretty sweet though.
Posted: Thu Apr 19, 2007 6:05 pm
by 84_4x4
3/4 way up gauge is great if not normal so you dont have a thing to worry about
Posted: Thu Apr 19, 2007 7:04 pm
by ranger5.0
3/4 of the way is pretty good. I would like to see it move though (higher when cold, lower when ran for a while).
Posted: Thu Apr 19, 2007 8:26 pm
by EBSTEVE
The 5L oil pressure should be around 50 psi.
Posted: Fri Apr 20, 2007 10:39 pm
by Roger
Hey, I have a 92 bird w/ a 5.Oh, and i want to say it is like 90 ohms at full and 0 at empty. check tccoa.com they have good write ups.
