				shifter boot
				Posted: Fri Apr 06, 2007 10:22 pm
				by worth165
				I have a 87 b2 witrh 5speed manual and four wheel drive, and my boot has a huge hole in it. I tried LMC truck but they have discontinued the part. Does anybody have any ideas?
				Posted: Tue Apr 10, 2007 7:14 pm
				by bower100
				Is'nt your boot sorta like two boots with a "divider" trim plate between them? If so, is your 5 sp. manual shift boot torn or the 4x4 boot?
 I'm thinking you might be able to splice a good boot onto the good half of your boot. ( If you follow me).
 dave
				Posted: Tue Apr 10, 2007 7:17 pm
				by 84_4x4
				rtv black silicone dont work?
				tare
				Posted: Wed Apr 18, 2007 7:53 am
				by worth165
				bower100 wrote:Is'nt your boot sorta like two boots with a "divider" trim plate between them? If so, is your 5 sp. manual shift boot torn or the 4x4 boot?
 dave
the boot is torn way to badly. the trans shop that replaced my trans rip it when the pulled it off.
				Posted: Fri Apr 20, 2007 2:15 pm
				by cddavis9343
				if its the tranny boot i think i got one in the shop (i think) i'll check and get back to ya
				Posted: Sat Apr 21, 2007 8:35 am
				by cddavis9343
				i got it if ya want it.  it came off a mitsu tranny i don't think that matters though.
				I will take it
				Posted: Tue Apr 24, 2007 11:19 am
				by worth165
				How much do you want for it?
				Posted: Thu Apr 26, 2007 4:14 pm
				by cddavis9343
				all i have is the shifter boot (item 3 on the diagram)
				boot
				Posted: Fri Apr 27, 2007 6:41 am
				by worth165
				thanks for looking
				Posted: Sat Apr 28, 2007 9:38 am
				by bower100
				If your boot is the same as the "double boot" for the automatic tranny shifter /  4x4 shifter combo, then I might have that. The photo looks the same as my boot and the listing info does'nt say it won't fit the auto tranny combo. (Item #5 just says 5 speed).
 If you measure the dimentions of your mounting screw holes on the black plastic floor trim piece, I'll tell you if it's the same as mine.  Trim piece the same.... boot should be too.
 dave
				post a pic
				Posted: Mon Apr 30, 2007 6:50 am
				by worth165
				Can you post apicture of what you have?
				shifter...
				Posted: Sun May 20, 2007 1:31 pm
				by spidogg1
				Hey...as long as we're in the neighborhood, do you have a diagram of the shifter itself? Have a 5 spd overdrive that is mighty loose, 85...thanks. P
