Alternater?
				steiner_5000
Alternater?
Is my alternater bad?  It's not charging my battery and my truck wont run with the lights on.  So I took a volt meter to it and it only read 12.8 volts.  I was taught in school that it needed to be at 14 volts.  Is this right?
						12.8 volts tell me that you have a good charge. If you had 11.8 then I would worry a little. An easy way to tell if the alt is bad is to disconnect the positive wire from the battery. The vehicle will die if the alt doesn't have a charge. 11 volt to 13 is normal. Most batteries that are good are in the 12.5 to 13.5 range. I have yet to find one that puts out a full 14 volts.
