I have an 8.8 from a '92 explorer (to install in my '84 bronco II) and have an idea for a cheap lift in the process. Let me know what you think on performance for off road, shock mounting, etc....
I want to use the frame perches from the explorer wich will put the leafs directly below the frame instead of beside it like the stock ones. Doing this and mounting the axel below the springs like the stock 7.5 should give me 5" of lift or so and a good bit of wheel travel / flex.
My big questions are how well it will work, how stable it will be, how prone to side to side bounce, and where to mount the shocks.
This is my dedicated trail rig but I still have to have it road worthy. I also will be installing the D-35 front driveline from the same explorer with a 4" lift (hub to hub should be 3" wider stance? ) and any insight to doing this would be appreciated.
Let me know what ye-all think !!!
410fortune Owes ME $$$ !
