Electrical Click
Posted: Tue Jan 30, 2007 8:17 am
by steiner_5000
I Just got my 4.0 in and is ready to start but I cant get it to turn over. The solenoid just makes one big "Thump" or "click" noise. Did I wire something wrong. How do I fix this?
Posted: Tue Jan 30, 2007 11:36 am
by Limited
I assume you have lots of power at the batt? If not thats your problem.
But if you did a swap than I am sure you would have checked that
Posted: Tue Jan 30, 2007 11:58 am
by 84_4x4
check all electrical connections from bat to start sylinoid and from there to starter and then check all grounds
Posted: Tue Jan 30, 2007 7:59 pm
One obvious question would be, Have you tried turning the engine by hand? Could be something mis aligned not lettin the engine turn over?
Posted: Wed Jan 31, 2007 10:53 am
by steiner_5000
I am fairly sure everything is connected and I know the battery has charge because I charged it yesterday and it has 12.4 volts. I pulled out the starter to see if it was hitting but the solenoid still just clicked. I went through the wires from starter to battery and everything looks good and even got out the wiring diagram to make sure everything is right. And I "tapped" on the starter with a hammer and still the same thing. This happen to anyone else?
Posted: Wed Jan 31, 2007 4:08 pm
by 84_4x4
if was clicking with starter out then jump the starter syliniod with the key ON is this starts it you will need a sylinoid if not then a starter
Posted: Thu Feb 01, 2007 7:38 am
by steiner_5000
But the starter worked when I pulled it out. Can it just go bad in 2 weeks from sitting?
Posted: Thu Feb 01, 2007 8:04 am
by 84_4x4
just becuase the starter worked when pulld out does not mean its strong enough to turn over the engine try to turn the engine over by hand using a socket and 1/2 drive on the harmonic balencer and if it will not turn then you have something internal preventing it if it does turn replace the starter
Posted: Thu Feb 01, 2007 9:40 pm
by pigmy pony
Just in case make sure the neutral start on the tranny is hooked up
Posted: Fri Feb 02, 2007 7:34 am
by Hair
if you are still useing the federwell solenoid you may have missed a wire
see the wire from the battery lead post to the starter solenoid post?
if you did not do that then that could explain it!
Posted: Sat Feb 03, 2007 7:52 am
by Bob Myers
what starter are you using? what starter did your old engine use? This info would be helpful to point you to the problem.
