axles
jake84duce
axles
Post by jake84duce »
i want to go with a wider wheel base and i cant aford the bigs guns like dana 44s and ect what can i pull out the junk yard to get rid of the front sisoior and go with leaf is it worth it. o i would have a pic of my 84 bronco2 but cant find the the plug wire to down load its a 84 with 3inch body with a major fender cut to fit my 35 15.50 15 swampers tls totlly gutted out elc. fan jeep windows snap tipe made by me actully works great and looks cool.
rockcrawlerbronco2
axles
Post by rockcrawlerbronco2 »
im confused you say wider wheelbase?wheelbase is the length between your front and rear axle.do you mean you want to go with wider axles?if so your only intellegent option would be to go with an early bronco 44 its way cheaper and easier than converting to leafs.
