				Help pulling springs
				Posted: Fri Dec 29, 2006 2:47 pm
				by nickb
				OK this might be a stupid question. I'm going to a U-pull it junk yard for explorer spings, I can't take a torch or a generator in the yard. So what would be the easiest way to get all the springs off and what size wrenchs would I need? Thanks for any help on the easiest way to get these off
				Posted: Fri Dec 29, 2006 5:52 pm
				by 84_4x4
				not sure on wrench sizes but i would say pb blaster and a bfh (big flippin hammer) maybe some propane torch if thats allowed to put some heat to em if the bolts are stuck
				Posted: Fri Dec 29, 2006 6:34 pm
				by Phillippi
				If they will let you take a sawsall cordless take it and cut the spring hangers off.  Cut the u-bolts as well for a quik pull.  If not take a socket set and a can of PB blast.  Still should take too long.  Maybe a cheater bar about 3' in case you need the leverage.  Good luck.
				Posted: Tue Jan 09, 2007 4:35 pm
				by bower100
				nickb,
 This might be too late to help you, but in case not here goes.
  Just two days ago ,I wastrying to get the springs off a 1992 Sport Explorer thats going to the junkyard.
 The u-bolt nuts  on both the Explorer and the BII are 18mm...deep socket needed for the Explorer.
 The spring eyebolts and nuts are 21m.
  dave
