hooking up a tach?
Posted: Wed Dec 06, 2006 9:01 am
by 86_bronco_2
well i want to hook up a tachometor, its a 86 bronco II. does anyone know what wire from the ignition coil is the neg. or what ever i need to splice the signal feed wire from the tach into?
thanks for any help, jeremy
Posted: Wed Dec 06, 2006 9:17 pm
Splice into the green wire going to the coil.
Posted: Thu Dec 07, 2006 11:54 am
by 84_4x4
the green one is the neg and the pos i believe is white but you wont need to mess with that
Posted: Fri Dec 08, 2006 7:40 pm
by ranger5.0
It is the green wire. Usually there is a test port on the coil that a female spade connector will plug right into. That way you won't have to cut a wire.
Posted: Fri Dec 08, 2006 10:26 pm
by 86_bronco_2
hey thanks for the help guys!
