Rear axle play
Rear axle play
Today I noticed that I could push my rear passenger side axle in and out about a 1/4''. What is worn to give this much play?
				greenmachine89
If have what most have then your c clips are a little worn and not caused for any concern. If you must you can take the rear diff cover off and inspect everything. Also since you have a semi floating axle you could be getting a little play from your bearings also.
 Hope this helps
