				see how mechanically inclined you are
				Posted: Tue Oct 24, 2006 8:02 pm
				by 84_4x4
				ok i went out to start my bronco 2 the other day and it turned over but would not fire so i checked spark and i had spark on all 6 cylinders so i checked fuel and i had good fuel pressure to my carburator. but when i would turn it over no fire and occasionally a little backfire out the carn shooting gas all over the bottom of my hood. i couldent figure out my problem but was a simple fix do you know the answer if so reply see how smart you are when seams impossible
				Posted: Tue Oct 24, 2006 9:12 pm
				by mccutcheon4
				Loose nut behind the wheel ?
				Posted: Wed Oct 25, 2006 8:42 am
				by Bob Myers
				SOunds like someone has been messin with the timing, either cam or dist, or both
				Posted: Wed Oct 25, 2006 4:15 pm
				by 84_4x4
				close but nothing was adjusted does have something to do with distributer
				Posted: Thu Oct 26, 2006 4:08 am
				what motor are you working on? I am quessing a 2.8?
what does the voltage look like going to the coil?
				Posted: Thu Oct 26, 2006 9:59 am
				by Joel H
				Sounds like your fireing order was all messed up. Out by one were you?
				Posted: Thu Oct 26, 2006 11:58 am
				by 84_4x4
				eh distributer cap was wet sending voltage to every piston at same time but some of yall were very close
