buckets in the back of a BII, anyone try yet.
I was wondering if anyone has tried to install regular buckets in the rear of a broncoII I was thinkin about moving my fronts to the back and getting some new fronts
i have never seen this or thought about it but would love to see it once finished but not sure they will fit since you have wheel wells in the back that you would have to go between but not sure if would fit or not i would take some measurements before starting cutting
Here's an interesting thread from the old Forum
http://www.broncoii4x4.com/cgi-bin/yabb ... 060;start=
There is rumor of having factory buckets. I've never seen any pictures of it. That one guy with the tripod account no longer has them up.Nobody wrote:Here's an interesting thread from the old Forum
But that removable window idea...........Ohh that gives me some ideas.
Me and a guy from Alaska have been talking about making canvas/poly windows that would pop inplace of the factory window then this way you could cruize around in the summer with the windows out then in the winter you just pop your glass back in.
the 86 does have the bolts, mine did anyway....
I would suggest building a sub frame for them so that you can bolt the seats to that. Your not going to need the slider mech so you can tuck it closer to the floor.84_4x4 wrote:back to the buckets has anyone taken any measurements beforeto see if the front seats would even fit if so i might be making me a trip to the junkyard lol
You might want to make a rail system that when putting the seats in you can slide them in and bolt the front down like the factory seats. The back would just hook into a channel. since you may not be able to accessany rear mounts.
deathmetalandrez
on my 85 and 89 b2's both had glued AND screwed windows. i had to first unbolt them, then use a hunting knife to cut the seals. I cut back the interior body panels and im going to attempt to make removable windows. that would be awesome, and less work then making it a convertible. seeing as the b2's nearly have bay windows in the back, it would be a much better substitute.
I currently own 4 bronco 2's. Three of them are 89' of which two are 4x4 and love em. The other is an 85' 4x4 5-spd
breefee_BII
breefee_BII
breefee_BII
I'm the wrong person to ask the first thing I did was chop my top off. but I think you could probably hinge it from the inside with some pins to pull or something along those lines. As long as you can see the threads on the bolts you could probably modify something but the sealing will be your biggest challenge I'm sure.
IF YOU GOT IT BREAK IT
