That's a lot of money for an incomplete axle, small bearing at that. The small bearing 28 spline axles are quite a bit weaker than the big bearing 28 spline axles. You can get 31 spline axles, but then you need a custom axle bearing and I don't like that. Then the axle tube flanges are a different pattern, and to top it all off it's the old style housing.
I would really suggest holding out for a big bearing axle. Get a fullsize 9" with the updated trussed housing, then have it cut down. There has to be someone in you area that does it. We can get complete axles from the junkyard for $80.
As for the carrier, technically pic above is the 3rd member. The actual carrier would be your open diff, LS, or locker. I would have a hard time throwing money at 28 spline stuff, but in reality, it is plenty strong for what a lot of people would need.
It's a kind of a vicious cycle and it all revolves around the housing you choose. I only like to spend money once, so I always opt to hold out for what I want.
I'm in the same boat with my EB. It has a small bearing 9". I don't want to buy a 28 spline ARB, so I need to upgrade to 31 spline. But before I upgrade to 31 spline, I want a big bearing housing cut to the width I want.
Then if you stand back and look at cost, it's about the same or less to build a 35 spline 60. Especially once you consider the cost of a nodular 3rd member.
Guess that $200 for a small bearing housing isn't so bad after all
