lift kit
87bronc
lift kit
Post by 87bronc »
hey whats up i have a 87 bronco II that is currently lifted im guessing like 2" suspension and 2" body i bought it that way so im not sure. anyways it is on 31"s. i want to put some 20x10 with a 33x13x20 tire on it and give it some more lift as well and im wondering what u guys think would be the best and most affordable option for a 6" lift kit. email me with ur opinions at chvy91bowtie@aol.com thanks
thats siccccccc
well, first off the forum is here so everyone can see how to work on there trucks. so you will have to come here to get them...
as to your question...why do you want 20's? if you are using this truck for street only then I can understand but you are going to have several problems. first is the brakes, they are not made to handle the extra rotating mass. the second is I have yet to see a BII or explorer look good with 20's. the third is you are going to spend more on the rims and tires then the truck is probably worth.
if you doing this to go with larger tires and get less side wall, I remeber seeing an article in one of my offroad mags that explained that 20's would only help if you were running 44's and unless you have upgraded to a D60 that would be axle joint suicide...
