too cheap for chiltons where the relay
breefee_BII
well every time i try and start the BII it won't start and i got nuthin for fuel pressure. checked and bypassed the inertia switch and still nothin. fuses are good but i'm not sure which of the four relays on the pass side are the fuel pump relay any help would be great thanks. seriously i'm broke after all the crap i bought last month for this thing. 78 d44 is next
IF YOU GOT IT BREAK IT
try switching them around. if you look at the relays some of them have the diagram on them and if you find two that are the same you can swap them and try your luck. also take a few of them in to the parts house and match them up with what they got.
I want to say the relays are only like $10-$15
