Constant Velocity Joint problems (cv joint)
BlueBronc
Post by BlueBronc »
Here's my setup:
1987 Bronco II 4WD
Chevy SB V8 283, Ford 5-Speed Manual (stock)
I pulled my rear drive train today and there is a chunk that cracked off of the cage that holds the bearings in place and the spring and cap inside the flange are all cracked up and shot.
I want to replace the CV Joint, and possibly the whole driveshaft (flange, etc), but I'm not sure where to start looking. Does anyone know a web-site or where to find out which Explorers, or Bronco II's are compatible with mine? Can I use a Cardan U-Joint with this setup and just replace the yoke?
Any help would be great.
Here's a picture of what my the drive shaft looks like:
those driveshafts are junk. IMO you should go and get the 3 u-joint setup. they call it a CV shaft also. you can order them from duff or go and look in the yards to make something work. buying it new from duff or another distributor usually cost around $230-$250 but it is worth everypenny
worth165
drive line
Post by worth165 »
if you are in washington call northwest drivelines . 230 dollars instock mine is unbreakable
Re: drive line
Post by tekatlarge »
worth165 wrote:if you are in washington call northwest drivelines . 230 dollars instock mine is unbreakable
Shouldn't that be "Drivelines Northwest"
http://www.drivelinesnw.com/
Phone 1-800-552-7647 Fax 206-622-7609
