what's the trick to swap ignition modules what socket size !
Posted: Tue Jul 18, 2006 12:51 am
by lookn4dirt
got a 2.8 84 bII need to swap out an ignition module but muh sockets won't reach and muh deeps don't seem to fit ? what size is the screws and is there a trick to getting it off ?? Thanks guys !!
Posted: Tue Jul 18, 2006 2:44 am
by FatMan
if i remember correct on my 89 fullsize it was a weird metric size something like 6.5 or 5.5 mm... i do remeber it being a pain in the a$$ though.
Posted: Tue Jul 18, 2006 9:03 am
by lookn4dirt
thanks a TON, I'll go buy some today. stupid little sockets !!!! ;)
Posted: Tue Jul 18, 2006 10:13 am
by LarryA
If you find the correct size and it will not fit into the hole leading to the screw/bolt, there is a trick we used to do but it will weaken the socket for other uses. Get the right size and grind the sides thinner so it fits into the recess. I did this to get the module off my '90 B2 distributor but I can't find the socket right now to tell you what size it was. It may have even benn a standard six point nut driver I did the grinding on. At any rate the thinning allows the socket to get to the bolt.
Posted: Tue Jul 18, 2006 9:44 pm
by eisle89
Or go to AutoZone and buy the tool for $5
Posted: Wed Jul 19, 2006 9:07 am
by desrt_rat
that would be to easy plus i like to be creative.
